Charge or sync your Apple devices, even when inside a protective case. The USB2ADC1MB 1-meter Apple 30-pin Dock Connector to USB cable for iPhone, iPod and iPad is colored to suit black mobile devices and provides reliable connectivity of your iOS-enabled mobile digital devices to your computer, for syncing and charging.
Plus, this uniquely constructed Dock Connector to USB cable features a stepped Apple Dock Connector, designed by StarTech.com, which unlike a regular connector plugs into your iPhone, iPod or iPad, even when inside a protective case while avoiding the inconvenience of having to constantly remove the cover for every charge/sync.
This durable cable is Apple MFi certified.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 1m 30-pin Dock to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
- StarTech.com 1m Black Apple 30-pin Dock to USB Cable iPhone iPod iPad - charging / data cable - 1 m
- Cable
- Charging / data cable
- American Wire Gauge (AWG)
- 22/30
- Length
- 1 m
- Black
- Connector
- USB - male
- Connector (Second End)
- Apple Dock - male
- Limited lifetime warranty
- Designed For
- P/N: ST4CU424, ST4CU424EU, ST4CU424UK, ST7C51224, ST7C51224EU, ST7CU35122, ST8CU824
- Cable Type
- 22/30
- Jacket Material
- PVC
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 1 m
- Plated Connector
- Nickel
- Black
- Connector
- 4 pin USB Type A - male
- Apple Dock connector - male
- RoHS
- Limited warranty - lifetime
- Designed For
