StarTech.com 1m 3.5mm 4 Position TRRS Headset Extension Cable - M/F
Quicklinx: 87N6WS00 Mfr#: MUHSMF1M
Length: 1m
Select:
£4.31 ex VAT
£5.17 inc VAT
The MUHSMF1M 4-Pole 3.5mm headset extension cable (1m) features a 3.5mm (1/8" TRRS) audio connector on one end and a 3.5mm (1/8" TRRS) audio connector on the other, making it easy to extend the reach between your hands-free headset or headphones, and your iPhone, mobile phone or laptop computer.
To ensure long-lasting performance, this high quality 3.5mm audio extension cable features molded PVC strain relief at each of the 1/8" TRRS connectors, which prevents the cable termination points from bending at sharp angles, in turn reducing the risk of cable damage.
To ensure proper hardware detection, it's recommended that the external headset be plugged into the adapter first, before the adapter is connected to the computer or mobile device.
StarTech.com 1m 3.5mm 4 Position TRRS Headset Extension Cable - M/F - headset extension cable - 1 m
Cable
Headset extension cable
American Wire Gauge (AWG)
28
Length
1 m
Connector
4-pole mini jack - male
Connector (Second End)
4-pole mini jack - female
Moulded, strain relief
Cable Type
28
Jacket Material
PVC
Length
1 m
Plated Connector
Nickel
Connector
Mini-phone 3.5 mm 4-pole - male
Mini-phone 3.5 mm 4-pole - female
RoHS
Limited warranty - lifetime
87N6 StarTech.com 2m 3.5mm 4 Position TRRS Headset Extension Cable - M/F In Stock £2.63
87N6 StarTech.com 1m 3.5mm 4 Position TRRS Headset Extension Cable - M/F In Stock £4.31
Length: 1m
Price Range Ex VAT: 0 - 50
