Connect your Juniper 40GbE QSFP+ network devices with this cost-effective, passive Twinax copper cable. This 40G QSFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This passive twinaxial cable is a fully hot-pluggable, direct-attach cable, supporting 40 Gigabit Ethernet applications connected through QSFP+ (Quad Small Form-Factor Pluggable) ports.
Designed for short-length, high-speed interconnects, this low-power, low-latency Twinax cable is a cost-effective alternative to fiber-optic cable assemblies, supporting short-distance applications such as point-to-point in-rack network switch or server connections.
The QFXQSFPDAC1M is a reliable replacement cable for the Juniper Networks EX-QSFP-40GE-DAC50CM.
- StarTech.com Juniper QFX-QSFP-DAC-1M Comp SFP+ Twinax Cable - 1 m (3.3 ft.) - direct attach cable - 1 m - black
- Direct attach cable - SFF-8436
- Technology
- Twinaxial
- Shielding Material
- Copper
- Passive cable, Hot-pluggable
- Length
- 1 m
- Connector
- QSFP+
- Connector (Second End)
- QSFP+
- Black
- OEM Manufacturer Equivalent Part Number
- Juniper QFX-QSFP-DAC-1M
- 2-year warranty
- Network Cable Type
- Technology
- Twinaxial
- Copper
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 30
- Impedance
- 100 Ohm
- Length
- 1 m
- 1.8 cm
- 1.3 cm
- 72 g
- Black
- Connector
- QSFP+
- QSFP+
- FCC, RoHS, WEEE, MSA, RCM
- 2-year warranty
- 0 °C
- 70 °C
StarTech.com 0.5m 40G QSFP+ DAC Cable | In Stock | £72.66 |
StarTech.com 1m 3.3ft 40G QSFP+ DAC Cable | In Stock | £93.14 |
StarTech.com 3m 9.8ft 40G QSFP+ DAC Cable | In Stock | £104.40 |
