StarTech.com 1m (3ft) Yellow Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad
Quicklinx: 9J4LWS00 Mfr#: USBLT1MYL
Length: 1m
Colours:
£11.71 ex VAT
£14.05 inc VAT
Charge and Sync your Apple Lightning-equipped devices. The USBLT1MYL 1m Yellow Lightning to USB Cable for iPhone, iPod, and iPad provides a stylish and reliable solution for charging and syncing your Apple 8-pin Lightning mobile devices.
The cable is colored to suit your yellow iPhone 5c but it can be used with any of your Lightning iOS-enabled mobile devices - so don't be afraid to be colorful and select from any of he colored Lightning cables such as Pink, Green, Yellow or Blue. You can create the perfect color match with your iPhone or be creative with your own unique look!
Plus, the reversible 8-pin Lightning connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device.
This durable cable is Apple MFi certified.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 1m Lightning to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
StarTech.com 1m Yellow Apple 8-pin Lightning to USB Cable for iPhone iPad - Lightning cable - Lightning / USB - 1 m
Cable
Double shielded
American Wire Gauge (AWG)
24/28/32
Length
1 m
Yellow
Connector
Lightning - male
Connector (Second End)
USB - male
Sync and charge
Apple iPad Air; iPad mini; iPad mini 2; iPad with Retina display (4th generation); iPhone 5, 5c, 5s; iPod nano (7G); iPod touch (5G)
Cable Type
Lightning cable
Interface Supported
Lightning / USB
Double shielded
24/28/32
Jacket Material
PVC
Shielding Material
Length
1 m
Plated Connector
Nickel
Sync and charge
Yellow
Connector
Apple Lightning - male
4 pin USB Type A - male
RoHS
Apple iPad Air , Apple iPad mini , Apple iPad mini 2 , Apple iPad with Retina display (4th generation) , Apple iPhone 5, 5c, 5s , Apple iPod nano (7G) , Apple iPod touch (5G)
9J4L StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad In Stock £11.71
9J4L StarTech.com 1m (3ft) Black Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad In Stock £11.71
9J4L StarTech.com 1m (3ft) Blue Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad In Stock £11.71
Length: 1m
Price Range Ex VAT: 0 - 50
