StarTech.com 1m (3ft) White Apple 8-pin Slim Lightning Connector to USB Cable for iPhone iPod iPad
Quicklinx: 9M6ZWS00 Mfr#: USBLT1MWS
Colours:
The USBLT1MWS 1m Slim Lightning to USB Cable is colored to suit white iPhone, iPod, and iPad mobile devices and provides a reliable solution for charging and syncing your Apple devices with your PC or Mac computer, through an available USB port.
The cable offers a slim Lightning connector housing which plugs into your device even while it is inside a protective case, so you won't have the hassle of constantly removing the cover each time you charge or sync. Plus, the reversible 8-pin connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device.
This lightweight cable also provides a portable solution that makes it perfect for carrying as a laptop or iPad accessory.
The USBLT1MWS is Apple MFi certified.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 1m Lightning to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
StarTech.com 3 ' / 1m USB Lightning Cable for iPhone iPod iPad - White - Discontinued, Limited Stock, Replaced by RUSBLTMM1M (USBLT1MWS) - Lightning cable - Lightning / USB - 1 m
Cable
Shielded
American Wire Gauge (AWG)
24/32
Length
1 m
White
Connector
Lightning - male
Connector (Second End)
USB - male
Sync and charge
P/N: HB30C4AFS, ST73007UA, USB2PCARBK, USB2PCARBKS, USBLT2PCARW, USBUB2PCARB
Cable Type
Lightning cable
Interface Supported
Lightning / USB
Shielded
24/32
Jacket Material
PVC
Shielding Material
Length
1 m
Plated Connector
Nickel
Sync and charge
White
Connector
Apple Lightning - male
4 pin USB Type A - male
RoHS
9M6Z StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub In Stock £99.33
9M6Z StarTech.com 6 Port USB 3.0 / USB 2.0 Combo Hub with 2A Charging Port – 2x USB 3.0 & 4x USB 2.0 In Stock £44.71
9M6Z StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad In Stock £15.49
9M6Z StarTech.com 2m (6ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad In Stock £16.73
9M6Z StarTech.com 4 Port USB 3.0 Hub plus 3 Dedicated USB Charging Ports (2 x 1A & 1 x 2A) In Stock £57.29
9M6Z StarTech.com 3m (10ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad In Stock £21.43
9M6Z StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black In Stock £51.70
9M6Z StarTech.com Dual Port Car Charger with Apple 8-pin Lightning Connector and USB 2.0 Port In Stock £26.99
9M6Z StarTech.com USB Wall Charger 17W / 3.4A x2 In Stock £15.45
9M6Z StarTech.com 7 Port USB 3.0 Hub Desktop In Stock £71.57
9M6Z StarTech.com 7 Port Industrial USB 3.0 Hub In Stock £111.58
9M6Z StarTech.com 2x USB Wall Charger 17W / 3.4A In Stock £15.48
9M6Z StarTech.com 10 Port Industrial USB 3.0 Hub In Stock £131.78
9M6Z StarTech.com 10-Pt USB 3.0 Hub w/ Charging In Stock £66.89
9M6Z StarTech.com 4-Port USB 3 Hub + 2.4A DCP In Stock £43.39
9M6Z StarTech.com 7-Pt USB 3.0 Hub + Charge Pts In Stock £60.86
9M6Z StarTech.com 2x USB Car Charger 24W / 4.8A In Stock £12.35
9M6Z StarTech.com 2x USB Car Charger 24W / 4.8A In Stock £11.54
9M6Z StarTech.com 4 Port USB 3.0 Hub with USB C In Stock £44.99
9M6Z StarTech.com 4PT USB 3.0 Hub - Charge Port In Stock £34.39
