StarTech.com 1m (3ft) Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M
Quicklinx: 9KMRWS00 Mfr#: USB3AUB1MS
Length: 1m
17 in stock
£7.03 ex VAT
£8.43 inc VAT
Position your USB 3.0 Micro devices near your desktop or laptop computer easily, with a thin, more flexible cable. Does your regular USB 3.0 cable lift or push against your external hard drive causing it to move around on your desk? Are you forced to arrange your desk according to how your cable decides to bend and rest?
The USB3AUB1MS features a slim USB wire construction that makes it easier to install your USB 3.0 devices and enables you to place them as needed throughout your workspace. Plus, the thin Micro USB connector molding makes this a great cable for mobile USB 3.0 devices too - it lets you plug into your device without having to take it out of its case for every charge and sync.
Organize your desk and your office to match your needs. This durable, lightweight cable is approximately half the thickness of a regular USB 3.0 cable giving you the freedom to place your devices as needed and with minimal clutter. The flexible, thin cable also reduces strain on the connection and prevents damage to the USB 3.0 port on your device.
Replace the cable that came with your Micro USB mobile device or keep one as a spare while traveling.
As well as being ideal for connecting to your desktop devices, this cable provides the perfect solution for charging and syncing your USB 3.0 Micro B-equipped phones and tablets.
Stop removing the case from your phone or tablet every time you charge or sync your device. The cable offers a thin Micro USB connector molding that plugs into your device even while it's inside a protective case.
StarTech.com 1m 3ft Slim USB 3.0 A to Micro B Cable M/M - Mobile Charge Sync USB 3.0 Micro B Cable for Smartphones and Tablets (USB3AUB1MS) - USB cable - 1 m
USB cable
Shielded
Molded, strain relief, 5 Gbps data rate
Length
1 m
Connector
10 pin Micro-USB Type B - male
Connector (Second End)
9 pin USB Type A - male
USB 3.0
P/N: HB30A4AIB, HB30C4AIB, HB31C4AB, HBS304A24A, S2510BU33PW, S251BRU33, S251SMU33EP, SLSODDU33B, SM2NGFFMBU33, ST4CU424, ST4CU424EU, ST4CU424UK, ST8CU824, UNI251BMU33
USB cable
Shielded
American Wire Gauge (AWG)
26/32
Plated Connector
Nickel
Length
1 m
Connector
USB 3.0, RoHS
9KMR StarTech.com 2m (6ft) Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £8.21
9KMR StarTech.com 1m (3ft) Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £7.03
9KMR StarTech.com 0.5m (20in) Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £6.09
9KMR StarTech.com 15cm (6in) Short Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £5.26
9KMR StarTech.com 10ft Slim Micro USB 3.0 Cable In Stock £10.90
Length: 1m
Price Range Ex VAT: 0 - 50
