StarTech.com 1m (3ft) Pink Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad
Quicklinx: 9G6LWS00 Mfr#: USBLT1MPK
Colours:
Charge and Sync your Apple Lightning-equipped devices. The USBLT1MPK 1m Pink Lightning to USB Cable for iPhone, iPod, and iPad provides a stylish and reliable solution for charging and syncing your Apple 8-pin Lightning mobile devices.
The cable is colored to suit your pink iPhone 5c but it can be used with any of your Lightning iOS-enabled mobile devices - so don't be afraid to be colorful and select from any of the colored Lightning cables such as Pink, Green, Yellow or Blue. You can create the perfect color match with your iPhone or be creative with your own unique look!
Plus, the reversible 8-pin Lightning connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device.
This durable cable is Apple MFi certified.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 1m Lightning to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
StarTech.com 1m Pink Apple 8-pin Lightning to USB Cable for iPhone iPad - Lightning cable - Lightning / USB - 1 m
Cable
Double shielded
American Wire Gauge (AWG)
24/28/32
Length
1 m
Pink
Connector
Lightning - male
Connector (Second End)
USB - male
Sync and charge
Cable Type
Lightning cable
Interface Supported
Lightning / USB
Double shielded
24/28/32
Jacket Material
PVC
Shielding Material
Length
1 m
Plated Connector
Nickel
Sync and charge
Pink
Connector
Apple Lightning - male
4 pin USB Type A - male
RoHS
9G6L StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad In Stock £15.49
9G6L StarTech.com 1m (3ft) Black Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad In Stock £15.47
