Charge or Sync your iPhone, iPod, or iPad with the cable out of the way. The USBLT1MBR 1m Angled Lightning to USB Cable for iPhone, iPod, and iPad is colored to suit black mobile devices and provides a reliable solution for charging and syncing your newer generation Apple mobile devices with your PC or Mac computer, through an available USB port.
The angled Lightning connector positions the cable in such a way that it allows for easy access to your iOS-enabled mobile digital device in both portrait and landscape mode, even while charging.
Plus, the reversible 8-pin Lightning connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device.
This durable cable is Apple MFi certified.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 1m Lightning to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
- StarTech.com 1m 3ft Angled Black Apple 8-pin Lightning to USB Cable for iPhone iPod iPad - Angled Lightning Cable - Charge & Sync - 1 m (USBLT1MBR) - Lightning cable - Lightning / USB - 1 m
- Cable
- Technology
- Double shielded
- American Wire Gauge (AWG)
- 22/28
- Length
- 1 m
- Black
- Connector
- Lightning - male
- Connector (Second End)
- USB - male
- Angled connector
- 2-year warranty
- Cable Type
- Lightning cable angled connector
- Interface Supported
- Lightning / USB
- Technology
- Double shielded
- 22/28
- Jacket Material
- PVC
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 1 m
- Plated Connector
- Nickel
- Sync and charge
- Black
- Connector
- Apple Lightning - male
- 4 pin USB Type A - male
- RoHS
- Limited warranty - 2 years
