StarTech.com 1m (3 ft) Right Angle Apple 30-pin Dock Connector to USB Cable - Stepped Connector
Quicklinx: 8D6QWS00 Mfr#: USB2ADC1MR
Charge or Sync your iPhone, iPod, or iPad with the cable out of the way. The USB2ADC1MR USB cable for iPhone, iPod and iPad (1m) features a right-angled Apple (30-pin) Dock Connector which positions the cable in such a way that it allows you to easily access your iOS-enabled mobile digital device in both portrait and landscape mode, even while charging.
Plus, the USB to iPhone cable features a uniquely constructed stepped Apple Dock Connector, designed by StarTech.com. Unlike a regular connector, the exclusive stepped connector plugs into your iPhone, iPod or iPad, even when inside a protective case, avoiding the inconvenience of having to constantly remove the cover for every charge/sync.
This durable cable is Apple MFi certified.
As an alternative, StarTech.com also offers a 1m Left Angle Apple 30-pin Dock Connector to USB Cable (USB2ADC1ML), which provides the same convenience as this right-angled cable, but allows you to connect to your iPhone, iPod or iPad from the opposite direction.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 1m 30-pin Dock to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
StarTech.com Right Angle Apple 30-pin Dock to USB Cable iPhone iPod iPad - charging / data cable - 1 m
Cable
Charging / data cable
Shielded
American Wire Gauge (AWG)
26
Length
1 m
White
Connector
USB - male
Connector (Second End)
Apple Dock - male
Angled connector
Apple iPod (4G, 5G); iPod classic; iPod mini
Cable Type
Charging / data cable angled connector
Shielded
26
Jacket Material
PVC
Shielding Material
Length
1 m
Plated Connector
Nickel
White
Connector
4 pin USB Type A - male
Apple Dock connector - male
RoHS
Limited warranty - lifetime
Apple iPod (4G, 5G) , Apple iPod classic , Apple iPod mini
