Charge and sync your Apple devices in their protective cases, even in hard to reach areas and tight spaces. The USB2ADC1MUL Apple (30-pin) Dock Connector to Left Angle USB Cable for iPhone, iPod and iPad (1m) offers a simple and reliable solution for connecting iOS-enabled mobile digital devices to your computer, for syncing or charging.
The left-angled USB connector allows for connection in tight spaces while the stepped Apple Dock Connector, designed by StarTech.com, plugs into your iPhone, iPod or iPad even when inside a protective case, avoiding the inconvenience of having to constantly remove the cover for every charge.
This durable cable is Apple MFi certified.
As an alternative, StarTech.com also offers a 1m Apple 30-pin Dock Connector to Right Angle USB Cable (USB2ADC1MUR), which provides the same convenience as this left-angled cable, but allows you to connect to your PC or Mac computer or your USB wall/vehicle charger from the opposite direction.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 1m 30-pin Dock to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
- StarTech.com Apple 30-pin Dock to Left Angle USB Cable - charging / data cable - 1 m
- Cable
- Charging / data cable
- Technology
- Shielded
- American Wire Gauge (AWG)
- 22/30
- Length
- 1 m
- White
- Connector
- Apple Dock - male
- Connector (Second End)
- USB - male
- Angled connector
- Limited lifetime warranty
- Designed For
- P/N: ST7C51224, ST7C51224EU, ST7CU35122
- Cable Type
- Charging / data cable angled connector
- Technology
- Shielded
- 22/30
- Jacket Material
- PVC
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 1 m
- Plated Connector
- Nickel
- Sync and charge
- White
- Connector
- Apple Dock connector - male
- 4 pin USB Type A - male
- RoHS, MFI
- Limited warranty - lifetime
- Designed For
