StarTech.com 1ft USB A to USB mini Cable - M/F
Quicklinx: 7P4CWS00 Mfr#: USBMUSBMF1
Connect a Device with a Mini USB (male) Plug to Another Device through a USB-A (female) Port. The USBMUSBMF1 USB 2.0 to Mini USB Adapter Cable features a USB-A (male) connector as well as a USB Mini (female) molded connector, enabling you to connect a device with a Mini USB (male) plug to another device through a USB-A (female) port.
StarTech.com 1ft USB A to USB mini Cable - M/F - USB cable - USB to mini-USB Type B - 30 cm
USB cable
Length
30 cm
Connector
4 pin USB Type A - male
Connector (Second End)
Mini-USB Type B - female
USB / USB 2.0
USB cable
American Wire Gauge (AWG)
28
Length
30 cm
Connector
USB / USB 2.0, RoHS
