Connect a Device with a Mini USB (male) Plug to Another Device through a USB-A (female) Port. The USBMUSBMF1 USB 2.0 to Mini USB Adapter Cable features a USB-A (male) connector as well as a USB Mini (female) molded connector, enabling you to connect a device with a Mini USB (male) plug to another device through a USB-A (female) port.
- StarTech.com 1ft USB A to USB mini Cable - M/F - USB cable - USB to mini-USB Type B - 30 cm
- USB cable
- Length
- 30 cm
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- Mini-USB Type B - female
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB cable
- American Wire Gauge (AWG)
- 28
- Length
- 30 cm
- Black
- Connector
- USB / USB 2.0, RoHS
