StarTech.com 1ft Low Profile SATA to eSATA Plate Adapter
Quicklinx: 67CVWS00 Mfr#: ESATAPLT1LP
Length: 30cm
Type: SATA
£4.54 ex VAT
£5.44 inc VAT
This eSATA plate (low profile) adds external data support to any existing Serial ATA (SATA) controller, allowing you to connect external SATA (eSATA) storage to a computer. With support for data transfer rates of up to 300MBps, this external SATA plate allows you to take advantage of the increased data integrity provided by external hard drives or RAID devices that support eSATA connections. Connecting eSATA storage couldn't be simpler. Just install the plate into an open I/O low profile slot on your computer and connect the cables to the Serial ATA connectors on your motherboard or controller card. The slim SATA data cable connecting the motherboard or controller card SATA connection to ESATAPLT1LP is designed to take up minimal space inside the computer case, providing less clutter for increased airflow inside your case.
StarTech.com 1ft Low Profile SATA to eSATA Plate Adapter - eSATA Slot Bracket - Low Profile SATA to eSATA Bracket (ESATAPLT1LP) - SATA internal to external panel - 30 cm
Interface Speed
Serial ATA 150/300/600
Low profile
Length
30 cm
Connector
7 pin Serial ATA - female
Connector (Second End)
7 pin external Serial ATA - male
Red
P/N: S251SMU33EP, S351BMU33ET, S351BMU33ETG, SDOCKU313E, SDOCKU33EF
Storage Cable Type
Interface Speed
Low profile
Length
30 cm
Red
Connector
RoHS
Length: 30cm
Type: SATA
Price Range Ex VAT: 0 - 50
