StarTech.com 19in Cable Management Panel
Quicklinx: C53GWS00 Mfr#: CABLMANAGER2
Product Type: Rack cable management kit
18 in stock
£23.15 ex VAT
£27.78 inc VAT
Organize and manage network, server and KVM cabling in your server rack. The CABLMANAGER2 1U Cable Management Panel mounts to a standard 19" 2 or 4-post rack to help you organize network, server or KVM cabling, using D-Ring hooks.
Constructed of high-quality steel, the cable organizer panel offers 5 removable ABS plastic D-Ring hooks, spaced 4in (105mm) apart for routing cables through your server rack and reducing cable strain. As an added benefit, the hook on either end of the panel can be turned 90° to accommodate horizontal or vertical rack cabling as needed.
Adding a cable manager in between equipment also functions to close off open spaces in the rack, promoting proper airflow.
StarTech.com Server Rack Cable Management - 1U -19" Metal Rackmount Panel - rack cable management kit - 1U - 19"
Height (Rack Units)
1U
1-year warranty
P/N: RK1224WALHM, RK1232WALHM, RK1233BKM, RK12WALHM, RK12WALLO, RK12WALLOA, RK1520WALHM, RK15WALLO, RK15WALLOA, RK1820WALHM, RK1833BKM, RK2433BKM, RK2537BKM, RK2620WALHM, RK4236BKB, RK4242BK24, RK4242BK30, RK616WALM, RK8OD, RK920WALM, RK9WALM, RKCONS1708K, RKCONS1716K, RKQMCAB12V2, WALLSHELF8U
Height (Rack Units)
1U
Rack Size
19"
Limited warranty - 1 year
P/N: 2636CABINET, 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 45PATCH30RD, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, CAB1019WALL, RK119WALLV, RK1219SIDEM, RK1219WALH, RK1219WALHM, RK1219WALL, RK1219WALLOH, RK1224WALHM, RK1232WALHM, RK1233BKM, RK1236BKF, RK12OD, RK12WALHM, RK12WALLO, RK12WALLOA, RK1520WALHM, RK15WALLO, RK15WALLOA, RK1820WALHM, RK1833BKM, RK219WALLV, RK219WALVO, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK2620WALHM, RK319WALLV, RK419WALLV, RK419WALVO, RK419WALVS, RK419WALVSGB, RK4236BK, RK4236BKB, RK4236BKNS, RK4242BK, RK4242BK24, RK4242BK30, RK4242BKNS, RK616WALM, RK619WALL, RK619WALLGB, RK619WALLOH, RK619WALLV, RK812WALLO, RK812WALLOA, RK819SIDEM, RK819WALLOH, RK8OD, RK920WALM, RK960CP, RK9WALM, RKCONS1708K, RKCONS1716K, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12, WALLSHELF4U, WALLSHELF8U
Price Range Ex VAT: 0 - 50
