Product
Brand
StarTech.com 18in Upward Right Angle SATA Cable with LP4 Adapter
Quicklinx: 76PYWS00 Mfr#: SATA18POWRAU
This 18in "upward" right angle SATA cable features an upward right-angled (90°) combination SATA data and power connector, that breaks out into one LP4 power (male) connector and one SATA data connector - allowing you to connect a Serial ATA drive to a power supply that may not offer a SATA power connector, as well as to the motherboard SATA controller.
The data segment of the cable uses the 7-pin SATA architecture to keep the cable ultra-thin, narrow and flexible, giving you more room and better airflow inside your case. The keyed contacts of the Serial ATA connector prevent broken or bent pins and allow a firmly seated connection with minimal pressure.
The right angled Serial ATA Data Cable is designed and constructed to provide a dependable and convenient SATA connection.
StarTech.com Upward Right Angle SATA Cable with LP4 Adapter - SATA cable - 45.7 cm
SATA cable
Interface Speed
Serial ATA 150/300/600
90° connector, molded, right-angled connector
Length
45.7 cm
Connectors
22 pin Serial ATA - receptacle
Connectors (Second End)
7 pin Serial ATA - receptacle , 4 PIN internal power - male
Red
Storage Cable Type
SATA cable
Interface Speed
Length
45.7 cm
Red
Connectors
RoHS
