Make a right side-angled connection to your SATA drive, for installation in narrow spaces. The SATA18RSA1 Right Side-Angled SATA Cable (18-inch) features one straight and one right side-angled (7-pin) data receptacle, which positions the cable so that it runs parallel to the drive ports - ideal for connectivity in narrow spaces, enabling installation of the drive as needed within the system case.
The cable also features a flexible low profile design that helps improve airflow and reduce clutter in your computer case, which helps keep the case clean and cool.
Constructed of only top quality materials and designed for optimum performance and reliability this 18" SATA cable supports full SATA 3.0 bandwidth (up to 6Gbps) when used with SATA 3.0 compliant drives.
- StarTech.com 18in SATA to Right Side Angle SATA Serial ATA Cable - SATA cable - 45.72 cm
- SATA cable
- Interface Speed
- Serial ATA 150/300/600
- Right-angled connector
- Length
- 45.72 cm
- Connector
- 7 pin Serial ATA - receptacle
- Connector (Second End)
- Red
- Limited lifetime warranty
- Designed For
- P/N: 25S22M2NGFFR, 25SAT22MSAT, S322M225R, SAT2M2NGFF25, SAT32M225, SAT32MSAT257
- Storage Cable Type
- SATA cable
- Interface Speed
- American Wire Gauge (AWG)
- 26
- Length
- 45.72 cm
- Red
- Connector
- RoHS
- Designed For
