This 18in IDE Drive Cable is designed to fit as a new or replacement hard drive/CD-ROM cable in almost any size of computer case. The cable features a rounded design that can help increase airflow capabilities within the computer case, and provide easier access to internal computer components.
The rounded IDE cable provides two 40-pin female drive connectors, for connecting both a master and slave device to the motherboard IDE bus through a single cable, saving the install space and cost of a second cable.
- StarTech.com IDE / EIDE cable - 0.5 m
- IDE / EIDE cable
- Interface Speed
- UDMA 66/100/133
- Length
- 0.5 m
- Connector
- 2 x 40 PIN IDC - female
- Connector (Second End)
- 40 PIN IDC - female
- White
- Limited lifetime warranty
- Designed For
- P/N: BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET425F, IDE2CF, IDE2SAT2, PCIIDE100R, PCIIDE2
- Storage Cable Type
- IDE / EIDE cable
- Interface Speed
- UDMA 66/100/133
- Length
- 0.5 m
- White
- Connector
- Designed For
