Product
Brand
StarTech.com 18in Round Dual Drive Ultra ATA IDE Hard Drive Cable
Quicklinx: 3ZLXWS00 Mfr#: IDE100RND18
This 18in IDE Drive Cable is designed to fit as a new or replacement hard drive/CD-ROM cable in almost any size of computer case. The cable features a rounded design that can help increase airflow capabilities within the computer case, and provide easier access to internal computer components.
The rounded IDE cable provides two 40-pin female drive connectors, for connecting both a master and slave device to the motherboard IDE bus through a single cable, saving the install space and cost of a second cable.
StarTech.com IDE / EIDE cable - 0.5 m
IDE / EIDE cable
Interface Speed
UDMA 66/100/133
Length
0.5 m
Connector
2 x 40 PIN IDC - female
Connector (Second End)
40 PIN IDC - female
White
P/N: PEXSAT2IDE2, PCISAT2IDE1, PCIIDE2, PCIIDE100R
Storage Cable Type
IDE / EIDE cable
Interface Speed
UDMA 66/100/133
Length
0.5 m
White
Connector
40 PIN IDC - female
StarTech.com 2 Port PCI IDE Controller Adapter Card, 2S1I PCI SATA IDE Combo Controller Adapter Card, 2S2I PCI Express SATA IDE Combo Controller Adapter Card
