Our checkout area is closed for maintenance, but should be back online soon. We apologise for any inconvenience caused
StarTech.com 18in Latching SATA Cable
Quicklinx: 4LTJWS00 Mfr#: LSATA18
Length: 46cm
Type: ATA
11 In Stock
£4.24 ex VAT
£5.08 inc VAT
SATA hard drive cable, with latching SATA connectors, for securely fastened hard drive installations. The LSATA18 SATA Cable features two latching 7-pin data receptacles and supports full SATA 3.0 bandwidth of up to 6Gbps when used with SATA 3.0 compliant drives.
The latching connectors lock when connected to a supporting (latchable) SATA port, ensuring a snug, and secured data connection every time to prevent accidental disconnects.
Featuring a low profile, yet durable construction, the flexible design improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
  • Secure connection
    The latched design of the cable provides a firm connection that prevents accidental disconnections, ensuring data remains uninterrupted during transfers.
  • High-speed compatibility
    This SATA cable supports speeds of 150, 300, and 600, making it suitable for a wide range of devices, enhancing performance for data-intensive applications.
  • Flexible length
    With a length of 1.5 ft, this cable is ideal for various setups, allowing for clean cable management without excess length clutter.
  • Easy installation
    Featuring receptacle connectors on both ends, the cable can be easily connected to SATA devices, streamlining the installation process.
  • Environmentally responsible
    This cable is RoHS compliant, indicating that it meets environmental safety standards and is free from hazardous materials.
StarTech.com 18in Latching SATA Cable - SATA cable - Serial ATA 150/300/600 - SATA (R) to SATA (R) - 1.5 ft - latched - red - LSATA18 - SATA cable - 46 cm
SATA cable
Interface Speed
Latched
Length
46 cm
Connector
7 pin Serial ATA - receptacle
Connector (Second End)
Red
P/N: 10P6G-PCIE-SATA-CARD, 2P6G-PCIE-SATA-CARD, 35S24M2NGFF, 4P6G-PCIE-SATA-CARD, 6P6G-PCIE-SATA-CARD, BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET425F, HSB13SATSASB, HSB1SATSASBA, HSB1SATSASVA, HSB225S3R, HSB43SATSASB, HSB4SATSASBA, PEXMSATA3422, PEXMSATA343, SATSASBP425, ST521PMINT
Storage Cable Type
SATA cable
Interface Speed
Latched
Length
46 cm
Red
Connector
RoHS
P/N: 10P6G-PCIE-SATA-CARD, 2P6G-PCIE-SATA-CARD, 35S24M2NGFF, 4P6G-PCIE-SATA-CARD, 6P6G-PCIE-SATA-CARD, BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET425F, DRW110SATBK, HSB13SATSASB, HSB1SATSASBA, HSB1SATSASVA, HSB225S3R, HSB2535SATBK, HSB3SATSASBA, HSB43SATSASB, HSB4SATSASBA, PEXESAT322I, PEXMSATA3422, PEXMSATA343, PEXSAT32, PEXSAT34RH, SATSASBP425, ST521PMINT, USB2SATAIDE, USB3SSATAIDE
4LTJ StarTech.com 18" Serial ATA Cable w/R Angle In Stock £5.00
4LTJ StarTech.com 8in Latching SATA to SATA Cable - F/F In Stock £5.44
Length: 46cm
Type: ATA
