StarTech.com 18in Latching Round SATA Cable
Quicklinx: 80H9WS00 Mfr#: LSATARND18
Connect latching SATA drives while helping to ensure optimal airflow throughout a desktop or server case. The LSATARND18 18-inch latching round SATA cable is a high quality SATA 6Gbps cable that features a rounded design to help improve airflow inside a computer or server case by providing less resistance as air passes around the cable, in turn helping to ensure optimal cooling for optimized system performance. This durable cable also features latching connectors, which lock when connected to a supporting (latchable) SATA port to, ensuring a snug, secured data connection every time to prevent accidental disconnects.
StarTech.com 18in Latching Round SATA Cable - 18 SATA Cable - 18 round SATA Cable - 18 latching SATA Cable (LSATARND18) - SATA cable - 45.7 cm
SATA cable
Interface Speed
Serial ATA 150/300/600
Latched, round
Length
45.7 cm
Connector
7 pin Serial ATA - receptacle
Connector (Second End)
P/N: 35S24M2NGFF, BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET425F, HSB13SATSASB, HSB1SATSASBA, HSB1SATSASVA, HSB225S3R, HSB2535SATBK, HSB3SATSASBA, HSB43SATSASB, HSB4SATSASBA, S251BU31REM, SATSASBP425, USB2SATAIDE, USB3SSATAIDE
Storage Cable Type
SATA cable
Interface Speed
American Wire Gauge (AWG)
30
Latched, round
Length
45.7 cm
Connector
RoHS
