This 18in internal USB IDC cable features two 5-pin USB motherboard header connectors, allowing you to connect a front panel USB hub or card reader directly to the motherboard header ports.
This cable provides a solution for connecting multi-function front panels, or any device that relies on internal USB ports, directly to the motherboard or expansion card offering USB an IDC (Header) connection without having to install additional cards, or run cables externally to the rear ports.
The 18in Internal IDC USB 5-pin Motherboard Header Cable is constructed of high quality materials and expertly constructed for durable performance.
- StarTech.com 5 Pin USB 2.0 Header - 18 in USB IDC Motherboard Header Cable - F/F (USBINT5PIN) - USB cable - 5 pin IDC to 5 pin IDC - 45.7 cm
- USB cable
- Length
- 45.7 cm
- Connector
- 5 pin IDC - female
- Connector (Second End)
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB cable
- American Wire Gauge (AWG)
- 24
- Length
- 45.7 cm
- Black
- Connector
- USB / USB 2.0, RoHS
StarTech.com 1 ft Panel Mount USB Cable - USB A to Motherboard Header Cable F/F | In Stock | £4.23 |
StarTech.com 18in Internal 5 pin USB IDC Motherboard Header Cable – F/F | In Stock | £2.89 |
StarTech.com 2 Port USB Motherboard Header Adapter | In Stock | £9.54 |
StarTech.com 6in USB 2.0 Cable - USB A Female to USB Motherboard 4 Pin Header F/F | In Stock | £4.20 |
StarTech.com 24in Internal 5 pin USB IDC Motherboard Header Cable F/F | In Stock | £3.29 |
