Connect your system LED panel status lights to your motherboard or hard drive controller. The IDC2PIN18, 18-inch Motherboard/HDD LED cable features two 2-pin header connectors, enabling you to connect your system LED panel status lights to your motherboard or hard drive controller.
- StarTech.com Internal 2 pin IDC Motherboard Header Cable - HDD LED cable - 2 pin IDC to 2 pin IDC - 45.7 cm
- HDD LED cable
- Length
- 45.7 cm
- Connector
- 2 pin IDC - female
- Connector (Second End)
- Designed For
- P/N: PEX4SFF8639
- HDD LED cable
- American Wire Gauge (AWG)
- 24
- Length
- 45.7 cm
- Connector
- RoHS
- Designed For
- P/N: PEX4SFF8639
