Turn a standard SATA motherboard connection into an external eSATA port. The ESATAPLT18IN 18-inch 1-port SATA to eSATA plate adapter adds external data support using an existing motherboard Serial ATA controller. Simply mount the plate to the rear panel of your computer cases an extension of the motherboard SATA data connector, in order to add a port for connecting external SATA storage devices (e.g. external eSATA hard drive).
Designed to take advantage of the increased data integrity provided by external hard drives or RAID devices that support eSATA connections, the eSATA-SATA adapter supports data transfer rates of up to 6Gbps.
- StarTech.com 18in 1 Port SATA to eSATA Plate Adapter - External SATA Plate - 6Gbps eSATA Port - Internal SATA to eSATA Adapter - 18 inch (ESATAPLT18IN) - SATA internal to external panel - 45.72 cm
- Interface Speed
- Serial ATA 150/300/600
- Length
- 45.72 cm
- Connector
- 7 pin Serial ATA - female
- Connector (Second End)
- 7 pin external Serial ATA - male
- Limited lifetime warranty
- Designed For
- P/N: S251SMU33EP, SDOCKU313E, SDOCKU33EF
- Storage Cable Type
- Interface Speed
- Length
- 45.72 cm
- Connector
- Designed For
