Brand
StarTech.com 18in 1 Port SATA to eSATA Plate Adapter
Quicklinx: 9PRPWS00 Mfr#: ESATAPLT18IN
Length: 45.72cm
12 in stock
£7.82 ex VAT
£9.38 inc VAT
Turn a standard SATA motherboard connection into an external eSATA port. The ESATAPLT18IN 18-inch 1-port SATA to eSATA plate adapter adds external data support using an existing motherboard Serial ATA controller. Simply mount the plate to the rear panel of your computer cases an extension of the motherboard SATA data connector, in order to add a port for connecting external SATA storage devices (e.g. external eSATA hard drive).
Designed to take advantage of the increased data integrity provided by external hard drives or RAID devices that support eSATA connections, the eSATA-SATA adapter supports data transfer rates of up to 6Gbps.
StarTech.com 18in 1 Port SATA to eSATA Plate Adapter - External SATA Plate - 6Gbps eSATA Port - Internal SATA to eSATA Adapter - 18 inch (ESATAPLT18IN) - SATA internal to external panel - 45.72 cm
Interface Speed
Serial ATA 150/300/600
Length
45.72 cm
Connector
7 pin Serial ATA - female
Connector (Second End)
7 pin external Serial ATA - male
P/N: S251SMU33EP, SDOCKU313E, SDOCKU33EF
Storage Cable Type
Interface Speed
Length
45.72 cm
Connector
9PRP StarTech.com 1 Port SATA to eSATA Slot Plate Bracket In Stock £6.36
Length: 45.72cm
Stock Status: In stock
