Brand
StarTech.com 17in Deep Vented Server Room Equipment Wall Mount Shelf
Quicklinx: 8BB6WS00 Mfr#: WALLSHELF
Product Type: Cabinet
£97.59 ex VAT
£117.10 inc VAT
Wallmount and store your non-rackmount server, networking or AV equipment. The WALLSHELF 17in Deep Vented Equipment Wall Mount Equipment Shelf provides an inexpensive and durable solution for wall mounting any non rackmount equipment in your server room.
An industrial-grade solution, the wall mountable shelf features a solid steel design with 16in spaced mounting holes (for standard wall studs), and supports a total weight capacity of up to 200 lbs (91 kg). For simple cable management, the shelf includes four pre-cut cabling holes with grommets, allowing you to easily route network, power, display or other cabling as needed.
StarTech.com 17in Deep Vented Equipment Wall Mount Equipment Shelf - Industrial Grade Server Room Shelf (WALLSHELF) - cabinet
Cabinet
Placing / Mounting
Wall mountable
Rack Size
17"
Product Material
Steel
52 cm x 43.2 cm x 35.5 cm
4.1 kg
Cabinet
Placing / Mounting
Wall mountable
Product Material
Steel
Rack Size
17"
52 cm
43.2 cm
35.5 cm
4.1 kg
Weight Limit
91 kg
RoHS
Limited warranty: - lifetime
8BB6 StarTech.com 1U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £39.44
8BB6 StarTech.com 2U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £37.84
8BB6 StarTech.com 8U Open Frame Wall Mount Equipment Rack - 12in Deep In Stock £75.78
