StarTech.com 16 Port Rackmount USB PS/2 Digital IP KVM Switch
Quicklinx: 4H1KWS00 Mfr#: SV1641HDIEGB
StarTech.com's SV1641HDIE revolutionizes remote server management by combining our industry-leading third generation Server Remote Control technology with a proven Enterprise class digital KVM switch.
The SV1641HDIE empowers you to securely manage up to eight computers remotely from almost anywhere using your LAN or the Internet. Unlike software solutions that require installation and work through your server's operating system, the SV1641HDIE gives you BIOS level control and full interaction with your system's boot process. Control does not come at the expense of security: SSH tunneling, SSL encryption, RADIUS authentication, and a configurable firewall are all included to ensure that your network stays secure. With both USB and PS/2 support, this switch easily handles a mixed platform environment to provide a central point of administration for all your servers. For added flexibility you can attach your existing KVM switches to the SV1641HDIE to remotely control up to 64 computers, and its standardized 1U rack-mountable metal chassis allows easy installation in your rack or cabinet.
Server Remote Control is about more than just servers. Using the Serial Remote Interface Module (RPORT) you can interact with virtually any device that uses a RS-232 serial terminal interface like routers, switches, environmental controls, alarm systems, and more. You can also use StarTech.com's 8 outlet Remote Power Module (PCM815SHNA) to power computers and equipment on an off using an interactive menu.
The SV1641HDIE is the perfect solution for any organization that demands secure, flexible local and remote administration of its critical systems.
Test drive Server Remote Control with a FREE online demo.
StarTech.com 16 Port RackMount USB PS/2 Digital IP KVM Switch - KVM switch - 16 ports - rack-mountable
KVM switch - 16 ports - cascadable
Enclosure Type
Rack-mountable 1U
Subtype
KVM
Ports
16 x KVM port(s)
KVM Users Qty
1 local user, 1 IP user
On-Screen Display, DHCP support, interrupt status port (ISP), VNC support, firmware upgradable
43.2 cm x 40.4 cm
4.2 kg
United Kingdom
1-year warranty
Enclosure Type
Rack-mountable 1U
Subtype
KVM
Ports
16 x KVM port(s)
KVM Local Users Qty
1 local user
KVM IP Users Qty
1 IP user
Keyboard / Mouse Interface
PS/2
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS
Max Resolution
1920 x 1440
On-Screen Display, DHCP support, interrupt status port (ISP), VNC support, firmware upgradable, IP-based user connection
16 x KVM HD-15 , 1 x VGA HD-15 , 1 x keyboard (PS/2) , 1 x mouse (PS/2) , 1 x LAN RJ-45
External power adapter
Plug and Play, FCC, RoHS
United Kingdom
43.2 cm
40.4 cm
4.2 kg
Limited warranty - 1 year
4H1K StarTech.com 6 ft 2-in-1 Ultra Thin USB KVM Cable In Stock £6.66
4H1K StarTech.com 10 ft Ultra Thin USB VGA 2-in-1 KVM Cable In Stock £9.64
4H1K StarTech.com 6 ft 3-in-1 Ultra Thin PS/2 KVM Cable In Stock £6.28
4H1K StarTech.com 15 ft 2-in-1 Ultra Thin USB KVM Cable In Stock £12.07
4H1K StarTech.com 12V DC 1.5A Universal Power Adapter In Stock £11.00
4H1K StarTech.com 10 ft Ultra-Thin USB VGA 2-in-1 KVM Cable In Stock £9.64
4H1K StarTech.com 6 ft Ultra-Thin USB VGA 2-in-1 KVM Cable In Stock £6.66
