StarTech.com's SV1641HDIE revolutionizes remote server management by combining our industry-leading third generation Server Remote Control technology with a proven Enterprise class digital KVM switch.
The SV1641HDIE empowers you to securely manage up to eight computers remotely from almost anywhere using your LAN or the Internet. Unlike software solutions that require installation and work through your server's operating system, the SV1641HDIE gives you BIOS level control and full interaction with your system's boot process. Control does not come at the expense of security: SSH tunneling, SSL encryption, RADIUS authentication, and a configurable firewall are all included to ensure that your network stays secure. With both USB and PS/2 support, this switch easily handles a mixed platform environment to provide a central point of administration for all your servers. For added flexibility you can attach your existing KVM switches to the SV1641HDIE to remotely control up to 64 computers, and its standardized 1U rack-mountable metal chassis allows easy installation in your rack or cabinet.
Server Remote Control is about more than just servers. Using the Serial Remote Interface Module (RPORT) you can interact with virtually any device that uses a RS-232 serial terminal interface like routers, switches, environmental controls, alarm systems, and more. You can also use StarTech.com's 8 outlet Remote Power Module (PCM815SHNA) to power computers and equipment on an off using an interactive menu.
The SV1641HDIE is the perfect solution for any organization that demands secure, flexible local and remote administration of its critical systems.
Test drive Server Remote Control with a FREE online demo.
- StarTech.com 16 Port RackMount USB PS/2 Digital IP KVM Switch - KVM switch - 16 ports - rack-mountable
- KVM switch - 16 ports - cascadable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- KVM
- Ports
- 16 x KVM port(s)
- KVM Users Qty
- 1 local user, 1 IP user
- On-Screen Display, DHCP support, interrupt status port (ISP), VNC support, firmware upgradable
- 43.2 cm x 40.4 cm
- 4.2 kg
- Localisation
- United Kingdom
- 1-year warranty
- Enclosure Type
- Rack-mountable 1U
- Subtype
- KVM
- Ports
- 16 x KVM port(s)
- KVM Local Users Qty
- 1 local user
- KVM IP Users Qty
- 1 IP user
- Keyboard / Mouse Interface
- PS/2
- Encryption Algorithm
- SSL
- Authentication Method
- Secure Shell (SSH), RADIUS
- Max Resolution
- 1920 x 1440
- On-Screen Display, DHCP support, interrupt status port (ISP), VNC support, firmware upgradable, IP-based user connection
- 16 x KVM HD-15 , 1 x VGA HD-15 , 1 x keyboard (PS/2) , 1 x mouse (PS/2) , 1 x LAN RJ-45
- Power Device
- External power adapter
- Plug and Play, FCC, RoHS
- Localisation
- United Kingdom
- 43.2 cm
- 40.4 cm
- 4.2 kg
- Limited warranty - 1 year
StarTech.com 12V DC 1.5A Universal Power Adapter | In Stock | £15.39 |
StarTech.com 6 ft Ultra-Thin USB VGA 2-in-1 KVM Cable | In Stock | £7.94 |
