StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables
Quicklinx: 7P2YWS00 Mfr#: SV1631DUSBUK
Type: KVM switch
Connectivity: KVM
Ports: 16
£468.79 ex VAT
£562.54 inc VAT
The SV1631DUSBUK 16 Port 1U Rack Mount USB KVM Switch Kit with OSD and Cables offers a well-appointed KVM switch that includes all of the cables and accessories required to connect to 16 servers or PCs right out of the box, making setup convenient and simple.
The USB KVM delivers a dependable computer management tool that allows you to control up to 16 USB-connected computers from a single keyboard, mouse and display, providing maximum control through hotkey command-based switching or front panel push-buttons, with the added configurability and convenience of an On-Screen Display.
A suitable addition to server room operations, the 16-port switch can be rackmounted into 1U of cabinet space and can be cascaded with multiple KVM switches to enable control of up to 136 computers from this single switch.
StarTech.com 16 Port 1U RackMount USB KVM Switch Kit with OSD and Cables - KVM switch - 16 ports
KVM switch - 16 ports - cascadable
Enclosure Type
1U
Subtype
KVM
Ports
16 x KVM port(s)
KVM Users Qty
1 local user
On-Screen Display
AC 120/230 V
54 cm x 18 cm x 4.5 cm
3.1 kg
3-year warranty
P/N: 2POSTRACK42, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK2236BKF, RK2536BKF, RK4236BK, RK4242BK
Enclosure Type
Desktop 1U
Subtype
KVM
Ports
16 x KVM port(s)
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
1920 x 1440 @ 60 Hz
On-Screen Display
Status Indicators
Port status, power
16 x KVM HD-15 , 1 x VGA HD-15 , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A
External power adapter
AC 120/230 V
16 x keyboard / mouse / video cable - 1.8 m
Rack Mounting Kit
Included
FCC, RoHS
54 cm
18 cm
4.5 cm
3.1 kg
Limited warranty - 3 years
5 °C
0 - 80%
7P2Y StarTech.com 6 ft 2-in-1 Ultra Thin USB KVM Cable In Stock £6.66
7P2Y StarTech.com 10 ft Ultra Thin USB VGA 2-in-1 KVM Cable In Stock £9.64
7P2Y StarTech.com 1U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £31.54
7P2Y StarTech.com 2U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £32.89
7P2Y StarTech.com Long Range USB VGA KVM Console Extender over Cat5 UTP - 1000 ft In Stock £288.86
7P2Y StarTech.com 12V DC 1.5A Universal Power Adapter In Stock £11.00
7P2Y StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £468.79
7P2Y StarTech.com 10 ft Ultra-Thin USB VGA 2-in-1 KVM Cable In Stock £9.64
7P2Y StarTech.com 6 ft Ultra-Thin USB VGA 2-in-1 KVM Cable In Stock £6.66
Type: KVM switch
Connectivity: KVM
Ports: 16
Price Range Ex VAT: 300 - 500
