StarTech.com 15U Wall-Mount Server Rack
Quicklinx: D5BHWS00 Mfr#: RK15WALLOA
Hurry, only 3 left in stock!
£119.23 ex VAT
£143.07 inc VAT
Mount your server or networking equipment to the wall, using this adjustable 15U open frame rack. This open-frame wall-mount server rack provides 15U of storage, helping you to save space and stay organized. The equipment rack features an adjustable depth and can hold a total of up to 198 lb. (90 kg).
With adjustable depth to as low as 12 in. (30.4 cm) this network rack is perfect for smaller spaces. It's easy to assemble and features wall-mounting holes that are spaced 12 and 16 in. apart, making it suitable for mounting on almost any wall, based on North American wall-frame stud-spacing standards. The wall-mount rack comes in a flat-pack, which makes it easy to transport and saves you money on shipping.
The open-frame rack adjusts from 12 to 20 in. (30.4 to 50.8 cm) to accommodate larger data, network, and telecommunication devices. The above-average depth also gives you the option to mount shelves and other accessories.
When space is limited you can mount the open-frame rack on a server room wall, office, or above a doorway, to expand your workspace and ensure your equipment is easy to access.
The rack's open frame design ensures passive cooling for your rack-mounted equipment. Additionally, the open frame provides easy access to your equipment and makes it easier to configure mounted devices, which saves you time.
StarTech.com 15U Wallmount Server Rack - Adjustable Rails - 19" Wide rack - 15U
Rack
Placing / Mounting
Wall mountable
Package Content
2 x vertical rails, 2 front horizontal brackets, 2 rear horizontal brackets, 16 assembly screws, 24 flat washers, 24 bolts, 60 x M6 cage nuts, 60 x M6 screws, 60 plastic washers
Rack Size
20"
Height (Rack Units)
15U
Product Material
Steel
50.4 cm x 30.5 cm x 77.5 cm
35.4 kg
Adjustable depth, 2 post
5-year warranty
Rack
Placing / Mounting
Wall mountable
Product Material
Steel
Package Content
Rack Size
20"
Height (Rack Units)
15U
50.4 cm
30.5 cm
77.5 cm
35.4 kg
Inner Dimensions
45 cm x 29.2 cm x 66.8 cm
Weight Limit
90 kg
Limited warranty - 5 years
StarTech.com 15U Wall-Mount Server Rack Bundle deal on StarTech.com 15U Wall-Mount Server Rack
£212.26
Price Range Ex VAT: 100 - 150
