Your basket is empty
StarTech.com 15m Snagless Cat6 Patch Cable - Yellow
Quicklinx: 819HWS00 Mfr#: N6PATC15MYL
Length: 15m
Colour: Yellow
25 in stock
£13.56 ex VAT
£16.27 inc VAT
Standard delivery Delivered within 3-5 working days
Make Power-over-Ethernet-capable Gigabit network connections. The N6PATC15MYL Cat 6 Patch Cable (15m) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable yellow PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Cat 6 Patch Cord delivers reliable performance.
StarTech.com Yellow Gigabit Snagless RJ45 UTP Cat6 Patch Cable / Cord - patch cable - 15 m - yellow
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Molded, snagless
Length
15 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Yellow
Network Cable Type
Patch cable - CAT 6
Jacket Material
PVC
American Wire Gauge (AWG)
24
Pairs per Cable
4 pairs
Plated Connector
Gold
Molded, snagless
Length
15 m
Yellow
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL - up to 500 MHz
Length: 15m
Colour: Yellow
Price Range Ex VAT: 0 - 50
