StarTech.com 15m QSFP+ Breakout Cable
Quicklinx: D9TZWS00 Mfr#: QSFP4X10AO15
Length: 15m
Colour: Black
£489.13 ex VAT
£586.95 inc VAT
Connect four Cisco 10GbE SFP+ network devices with this cost-effective, active optical cable. This QSFP+ breakout cable connects a single QSFP+ port to four 10G SFP+ ports and delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This active optical cable (AOC) is fully hot-pluggable and supports 40 Gigabit Ethernet applications connected through QSFP+ (Quad Small Form-Factor Pluggable) ports. The AOC cable is lighter and more flexible than QSFP+ direct-attach cables which makes it ideal for installation in tight spaces and over longer distances.
Designed for high-speed interconnects, this low-power, low-latency optical cable is ideal for applications such as point-to-point across-rack network switch or server connections, for up to four 10G SFP+ devices.
StarTech.com AOC Breakout Cable for Cisco QSFP-4X10G-AOC10M, 15m/49ft 40G 1x QSFP+ to 4x SFP+ AOC Cable, 40GbE / 40Gbps QSFP Plus Transceiver Module Active Optical Fiber, C9300, C3850 - Lifetime Warranty (QSFP4X10AO15) - breakout cable - 15 m - black
Breakout cable - SFF-8431/SFF-8432/SFF-8436
Fibre optic
Active cable
Length
15 m
Connector
QSFP+ - latched
Connector (Second End)
4 x SFP+ - latched
Network Cable Type
Fibre optic
Jacket Material
PVC
Active cable
Length
15 m
580 g
Connector
QSFP+ - latched
4 x SFP+ - latched
FCC, RoHS, MSA
70 °C
Length: 15m
Colour: Black
