Connect four Cisco 10GbE SFP+ network devices with this cost-effective, active optical cable. This QSFP+ breakout cable connects a single QSFP+ port to four 10G SFP+ ports and delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This active optical cable (AOC) is fully hot-pluggable and supports 40 Gigabit Ethernet applications connected through QSFP+ (Quad Small Form-Factor Pluggable) ports. The AOC cable is lighter and more flexible than QSFP+ direct-attach cables which makes it ideal for installation in tight spaces and over longer distances.
Designed for high-speed interconnects, this low-power, low-latency optical cable is ideal for applications such as point-to-point across-rack network switch or server connections, for up to four 10G SFP+ devices.
- StarTech.com Cisco QSFP-4X10G-AOC10M Compatible QSFP+ Breakout Cable - 15 m - breakout cable - 15 m - black
- Breakout cable - SFF-8431/SFF-8432/SFF-8436
- Technology
- Fibre optic
- Active cable
- Length
- 15 m
- Connector
- QSFP+ - latched
- Connector (Second End)
- 4 x SFP+ - latched
- Black
- OEM Manufacturer Equivalent Part Number
- Cisco QSFP-4X10G-AOC10M
- 2-year warranty
- Network Cable Type
- Technology
- Fibre optic
- Jacket Material
- PVC
- Active cable
- Length
- 15 m
- 580 g
- Black
- Connector
- QSFP+ - latched
- FCC, RoHS, MSA
- 2-year warranty
- 0 °C
- 70 °C
StarTech.com 15m QSFP+ Breakout Cable | In Stock | £1,002.30 |
StarTech.com 3m QSFP+ Breakout Cable | In Stock | £253.31 |
StarTech.com 5m QSFP+ Breakout Cable | In Stock | £431.39 |
StarTech.com 7m QSFP+ Breakout Cable | In Stock | £479.38 |
