This OM3 LC to LC Multimode Duplex Fiber Optic Patch cable features 50/125 micron fiber and supports high-bandwidth data transmission over a 10 Gigabit Ethernet connection.
With laser-optimized multimode fiber (LOMMF), the patch cable is ideal for connecting 850 nm Vertical Cavity Surface Emitting Laser (VCSEL) and LED sources. The high-speed connectivity on the aqua fiber-optic cable provides a high-bandwidth solution for your data centers or high-density applications.
Each OM3 fiber cable is individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
Housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, this fiber-optic cable ensures minimal smoke, toxicity and corrosion when exposed to high sources of heat, or in the event of a fire. It's the best choice for a wide range of environments, including industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
- StarTech.com 15m OM3 LC to LC Multimode Duplex Fiber Optic Patch Cable - Aqua - 50/125 - LSZH Fiber Optic Cable - 10Gb (A50FBLCLC15) - patch cable - 15 m - aqua
- Patch cable - OM3
- Technology
- Duplex fibre optic
- Type of Fibre Optics
- Multimode
- Halogen-free, Laser-optimized multimode fibre (LOMMF)
- Length
- 15 m
- Core / Cladding Diameter
- 50 / 125 micron
- Connector
- 2 x LC multi-mode - male
- Connector (Second End)
- Aqua
- Limited lifetime warranty
- Designed For
- P/N: SV565FXHD4KU
- Network Cable Type
- Patch cable - OM3
- Technology
- Multimode
- Jacket Material
- Low Smoke Zero Halogen (LSZH)
- Fibre Qty
- 2
- 50 / 125 micron
- Length
- 15 m
- Aqua
- Connector
- RoHS
- Designed For
- P/N: SV565FXHD4KU
StarTech.com 10m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC | In Stock | £37.56 |
StarTech.com 1m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC | In Stock | £18.89 |
StarTech.com 5m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC | In Stock | £28.29 |
StarTech.com 7m OM3 LC to LC Multimode Duplex Fiber Optic Patch Cable | In Stock | £27.76 |
