StarTech.com 15m Coax High Resolution Monitor VGA Video Extension Cable - HD15 M/F
Quicklinx: 87NGWS00 Mfr#: MXTHQ15M
Length: 15m
Stock Status: Clearance
Hurry, only 1 left in stock!
£16.01 ex VAT
£19.21 inc VAT
Express delivery Order within the next 7 hours for delivery on Monday
Extend your VGA monitor connection without losing video signal quality. The MXTHQ15M High Resolution VGA Extension Cable (15-meter) is designed to extend your VGA video connection while maintaining the highest video quality possible through VGA.
Ideally suited for high resolution VGA video applications, this high quality coaxial VGA extension cable (HD15 to HD15, M-F) helps eliminate the picture ghosting and fuzzy images that are inherent to non-coaxial cables, and features ferrite cores near the VGA connector ends to protect against EMI interference.
StarTech.com 15m Coax High Resolution Monitor VGA Video Extension Cable - VGA extension cable - 15 m
VGA extension cable
Triple shielded twisted pair coaxial
Molded, strain relief, ferrite core
Length
15 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - female
RoHS
VGA extension cable
American Wire Gauge (AWG)
28
Length
15 m
Connector
15 pin HD D-Sub (HD-15) - female
RoHS
87NG StarTech.com 15m Coax High Resolution Monitor VGA Video Extension Cable - HD15 M/F In Stock £16.01
87NG StarTech.com 10m Coax High Resolution Monitor VGA Video Extension Cable - HD15 M/F In Stock £23.03
Length: 15m
Price Range Ex VAT: 0 - 50
