Make VGA video and audio connections using a single, high quality cable. The MXTHQMM15MA 15-meter High Resolution VGA Cable with Audio is a high quality SVGA cable designed to provide the highest video quality possible through VGA - a single cable solution for connecting both video between a VGA video card and monitor, and audio connections between a sound card and external audio device.
StarTech.com's high resolution VGA cable with audio features high quality male-to-male coaxial VGA cable, and is designed to eliminate picture "ghosting" and fuzzy images that are inherent to non-coaxial cables, while providing superior EMI interference protection by using ferrite cores near the connector ends.
- StarTech.com 15m Coax High Resolution Monitor VGA Video Cable with Audio - VGA cable - 15 m
- VGA cable
- Technology
- Double shielded twisted pair triple coaxial
- Molded, thumbscrews, strain relief, ferrite core
- Length
- 15 m
- Connectors
- HD-15 (VGA) - male , Mini-phone stereo 3.5 mm - male
- Connectors (Second End)
- UL 2919, RoHS, NEC-CMG
- Black
- Limited lifetime warranty
- VGA cable
- Technology
- Shielding Material
- Aluminum mylar foil with braid
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Length
- 15 m
- Black
- Connectors
- 15 pin HD D-Sub (HD-15) - male , Mini-phone stereo 3.5 mm - male
StarTech.com Slimline Adapter HDDB15 F/F | In Stock | £5.03 |
StarTech.com Right Angle VGA to VGA Cable Adapter Type 1 - M/F | In Stock | £7.06 |
StarTech.com Right Angle VGA to VGA Cable Adapter Type 2 - M/F | In Stock | £7.03 |
