StarTech.com 15m Coax High Resolution Monitor VGA Cable - HD15 M/M
Quicklinx: 7P0DWS00 Mfr#: MXTMMHQ15M
Length: 15m
More than 50 in stock
£36.43 ex VAT
£43.71 inc VAT
Connect your VGA monitor with the highest quality connection available. This 15-meter high resolution VGA monitor cable is designed to provide the highest video quality possible through VGA.
Ideally suited for high resolution VGA applications, this high quality male-to-male coaxial VGA cable eliminates the picture "ghosting" and fuzzy images that are inherent to non-coaxial cables, while providing superior EMI interference protection by using ferrite cores near the connector ends.
StarTech.com 15m Coax High Resolution Monitor VGA Cable HD15 M/M - VGA cable - 15 m
VGA cable
Triple shielded twisted pair coaxial
Molded
Length
15 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
RoHS
VGA cable
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Molded
Length
15 m
Connector
RoHS
7P0D StarTech.com Right Angle VGA to VGA Cable Adapter Type 1 - M/F In Stock £6.09
7P0D StarTech.com 10m Coax High Resolution Monitor VGA Cable - HD15 M/M In Stock £23.03
7P0D StarTech.com 15m Coax High Resolution Monitor VGA Cable - HD15 M/M In Stock £36.43
7P0D StarTech.com 20m Coax High Resolution Monitor VGA Cable - HD15 M/M In Stock £49.74
Length: 15m
Price Range Ex VAT: 0 - 50
