StarTech.com 15m 49ft 40G QSFP+ AOC Cable
Quicklinx: D9V6WS00 Mfr#: QSFPH40GAO15
Connect your Cisco compliant 40GbE QSFP+ network devices with this cost-effective, active optical cable. This 40G QSFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This active optical cable (AOC) is fully hot-pluggable and supports 40 Gigabit Ethernet applications connected through QSFP+ (Quad Small Form-Factor Pluggable) ports. The AOC cable is lighter and more flexible than QSFP+ direct-attach cables which makes it ideal for installation in tight spaces and over longer distances.
Designed for high-speed interconnects, this low-power, low-latency optical cable is ideal for applications such as point-to-point across-rack network switch or server connections.
StarTech.com Cisco QSFP-H40G-AOC15M Compatible 5m/16.4ft 40G QSFP+ to QSFP+ AOC Cable, 40GbE QSFP+ Active Optical Fiber, 40Gbps/40GE QSFP Plus/Transceiver Module Cable, Firepower ASR1000 - Lifetime Warranty (QSFPH40GAO15) - 40GBase direct attach cable - 15 m - black
40GBase direct attach cable - SFF-8436
Twinaxial
Active cable
Length
15 m
Connector
QSFP+ - latched
Connector (Second End)
QSFP+ - latched
Network Cable Type
Twinaxial
Jacket Material
PVC
American Wire Gauge (AWG)
24
Impedance
100 Ohm
Active cable
Length
15 m
580 g
Connector
QSFP+ - latched
QSFP+ - latched
FCC, RoHS, MSA
70 °C
