StarTech.com 15in Laptop Privacy Screen - Matte or Glossy - 16:9 Ratio
Quicklinx: FNL9WS00 Mfr#: PRIVSCNLT15
More than 50 in stock
£38.87 ex VAT
£46.64 inc VAT
Notebook Privacy Filter, Blue Light Reduction Matte or Glossy 2-Year Warranty. The laptop privacy screen is easy to attach and remove. Simply attach the notebook privacy filter to your laptop using the magnetic strips. This black out privacy screen is also reversible. The matte side provides you with glare reduction and the glossy side of the privacy screen will provide you with increased clarity.
Protect your Privacy
The laptop privacy filter is a great investment if you want to protect your privacy. It is a convenient and cost-effective way to keep your classified information, intellectual property or any other important data you wish to keep protected. Whether travelling, working in the office or sitting in a busy coffee shop, you can have a peace of mind because you know your screen is protected with the 30+/- degree privacy viewing angle.
The display privacy filter is designed to filter blue light (390nm~480 wavelength) that can cause eye strain and can disrupt sleeping patterns.
The Choice of IT Pros Since 1985
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales.
This PRIVSCNLT15 is backed by a StarTech.com 2-year warranty and free lifetime technical support.
  • Easy magnetic installation
    The laptop privacy screen is very easy to install and remove. Simply attach the adhesive magnetic strips to the bezel of your display then align the notebook privacy filter with the strips. This black out privacy screen is also reversible. The matte side provides you with glare reduction and the glossy side of the privacy screen will provide you with increased clarity. In order to close and put your laptop to sleep the privacy screen must be removed. A protective folder is included so you can protect the privacy screen from damage when not in use. The privacy screen is also extremely easy to clean when removed from your laptop.
  • Protect your privacy
    The laptop privacy filter is a great investment if you want to protect your privacy. It is a convenient and cost-effective way to keep your classified information, intellectual property or any other important data you wish to keep protected. Whether traveling, working in the office or sitting in a busy coffee shop, you can have a peace of mind because you know your screen is protected with the 30+/- degree privacy viewing angle.
  • Blue light reduction
    The display privacy filter is designed to filter blue light (390nm~480 wavelength) that can cause digital eye strain and can disrupt sleeping patterns.
StarTech.com Laptop Privacy Screen for 15" Notebook - Removable Magnetic Laptop Security Filter - Blue Light Reducing - Matte/Glossy notebook privacy filter
Notebook privacy filter
Installation Type
Magnetic
Package Content
Wiping cloth, metal strip, L folder
Transparent
Product Material
Plastic
35.5 cm 21.3 cm
52 g
Display Screen Size Compatibility
15"
Anti-glare, reversible, +/- 30° visible angle, 25% blue light reduction
Product Material
Plastic
Package Content
35.5 cm
21.3 cm
52 g
25.9 cm 38.3 cm / 214 g
15"
Transparent
Display Filter
Installation Type
Magnetic
Aspect Ratio
16:9
Scratch Resistant
RoHS, REACH
TAA Compliant
Price Range Ex VAT: 0 - 50
