StarTech.com 15ft Coax High Resolution 90 degree Down Angled VGA Monitor Cable - HD15 M/M
Quicklinx: 6LC1WS00 Mfr#: MXT101MMHD15
Type: VGA
Length: 4.6m
Select:
£12.12 ex VAT
£14.54 inc VAT
Connect your VGA monitor with the highest quality connection available, even in tight spaces. This 15ft High Resolution Video VGA Cable (90 degree) is designed to provide the highest video quality possible through a VGA connection and is specifically constructed to accommodate tight installation spaces.
The high quality, shielded coax VGA cable features a 90 degree down-angled plug, which requires only 32.4mm (1.27") of space to make the video connection.
More than suitable for high-res VGA applications (1280x1024 resolution and above), the 90 degree VGA cable eliminates picture "ghosting" and fuzzy images that are common with non-coaxial cables, and provides superior EMI interference protection using ferrite cores near the connector ends.
StarTech.com "15ft Coax High Resolution 90° Down Angled VGA Monitor Cable - HD15 M/M (MXT101MMHD15)" - VGA cable - 4.6 m
VGA cable
90° connector, ferrite bead
Length
4.6 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
RoHS
VGA cable
American Wire Gauge (AWG)
28
Length
4.6 m
Connector
RoHS
6LC1 StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £5.74
6LC1 StarTech.com 10 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £10.05
6LC1 StarTech.com 25 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £17.08
6LC1 StarTech.com 6 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £6.00
6LC1 StarTech.com DVI to VGA Cable Adapter - M/F In Stock £4.87
6LC1 StarTech.com 3 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £6.29
6LC1 StarTech.com 35 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £23.83
6LC1 StarTech.com Right Angle VGA to VGA Cable Adapter Type 1 - M/F In Stock £6.09
6LC1 StarTech.com Right Angle VGA to VGA Cable Adapter Type 2 - M/F In Stock £6.09
Type: VGA
Length: 4.6m
Price Range Ex VAT: 0 - 50
