StarTech.com 15cm (6in) Short White Apple 8-pin Lightning Connector to USB Cable  iPhone iPod iPad
Quicklinx: 920CWS00 Mfr#: USBLT15CMW
Length: 15cm
Colours:
27 in stock
£11.70 ex VAT
£14.04 inc VAT
Charge and Sync your Apple Lightning-equipped devices with reduced clutter. The USBLT15CMW 6in/15cm Lightning to USB Cable for iPhone, iPod and iPad enables close-range syncing and charging of your Lightning-enabled mobile digital devices. The cable is short enough to minimize the clutter of excess cable, making it ideal for charging your device in your vehicle or syncing to your laptop. Plus, the shorter cable design provides a portable solution that makes it perfect for carrying as a tablet or laptop accessory.
The reversible 8-pin Lightning connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device.
This durable cable is Apple MFi certified.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 15cm Lightning to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
StarTech.com 6in Short White Apple 8pin Lightning to USB Cable iPhone iPad - Lightning cable - Lightning / USB - Lightning to USB - 15 cm
Cable
Double shielded
American Wire Gauge (AWG)
24/28/32
Length
15 cm
White
Connector
Lightning - male
Connector (Second End)
USB - male
Sync and charge
Cable Type
Lightning cable
Interface Supported
Lightning / USB
Double shielded
24/28/32
Jacket Material
PVC
Shielding Material
Length
15 cm
Plated Connector
Nickel
Sync and charge
White
Connector
Apple Lightning - male
4 pin USB Type A - male
RoHS, MFI
Length: 15cm
Price Range Ex VAT: 0 - 50
