StarTech.com 15cm (6in) Mobile Charge Sync USB to Slim Micro USB Cable for Smartphones and Tablets
Quicklinx: 9X91WS00 Mfr#: USBAUB15CMBK
Length: 15cm
17 In Stock
£4.54 ex VAT
£5.44 inc VAT
Charge and Sync your Micro USB-equipped Smartphone or Tablet with reduced clutter. The USBAUB15CMBK Micro USB Cable is perfect for close-range connections, and provides a reliable solution for charging and syncing your Micro USB mobile devices. Plus, the cable offers a slim design that lets you plug into your device without having to take it out of its case for every charge and sync.
The short 15cm cable length makes this an ideal charge cable for in-car use or to reduce clutter when syncing to your laptop - perfect for people on the move, for providing simple, tidy connections.
Replace the cable that came with your device and keep one as a spare in your laptop bag, backpack or other carrying case.
Stop removing the case from your phone or tablet every time you charge or sync your device. The cable offers a slim Micro USB connector molding that plugs into your device even while it's inside a protective case.
StarTech.com 15cm 6in Mobile Charge Sync USB to Slim Micro USB Cable for Phones & Tablets A to Micro B - M/M - Thin Micro USB Charge Cable (USBAUB15CMBK) - USB cable - Micro-USB Type B to USB - 15 cm
USB cable
Double shielded
Length
15 cm
Connector
5 pin Micro-USB Type B - male
Connector (Second End)
4 pin USB Type A - male
USB / USB 2.0
P/N: CMDPHD2HD, DPMDPHD2HD, ST4CU424, ST4CU424EU, ST4CU424UK, ST8CU824, USBAUBSCHM
USB cable
Double shielded
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
15 cm
Connector
USB / USB 2.0, RoHS
9X91 StarTech.com 0.5m Mobile Charge Sync USB to Slim Micro USB Cable for Smartphones and Tablets In Stock £4.27
9X91 StarTech.com 2m Mobile Charge Sync USB to Slim Micro USB Cable for Smartphones and Tablets In Stock £5.35
9X91 StarTech.com 1m Mobile Charge Sync USB to Slim Micro USB Cable - M/M In Stock £4.57
9X91 StarTech.com 15cm (6in) Mobile Charge Sync USB to Slim Micro USB Cable for Smartphones and Tablets In Stock £4.54
9X91 StarTech.com 3m USB / Slim Micro USB Cable In Stock £6.19
Length: 15cm
