Connect USB 2.0 peripherals to your computer. The USB2HAB15 15ft USB A-to-B cable features one USB 'A' male connector and one USB 'B' male connector, providing a high quality connection to USB 2.0 peripherals such as USB printers, scanners or external USB hard drives.
- StarTech.com 15 ft USB 2.0 A to B Cable - M/M - USB 2.0 Cable - Black - USB Type A (M) to USB Type B (M) (USB2HAB15) - USB cable - USB to USB Type B - 4.6 m
- USB cable
- Molded
- Length
- 4.6 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 4 pin USB Type B - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: ICUSB2324I, ICUSB232D, IPUSB2HD3, IPUSB2VGA2, PM1115UW, PM1115UWEU, ST12MHDLANU, ST12MHDLANUR, SV231DPDDUA2, SV231DVIUDDM, SV231USBDDM, SV431DL2DU3A, SV431DPUA2, SV431DVIUDDM, SV431USBDDM, SV565UTPDUV, SV565UTPHDU, USB2001EXT2NA, USB2002EXT2NA, USB2004EXT2NA, USB2HDCAPS, USB3EXT6INBK
- USB cable
- Molded
- Length
- 4.6 m
- Black
- Connector
- USB / USB 2.0, FCC
- Designed For
- P/N: ICUSB2324, ICUSB2324I, ICUSB2328, ICUSB232D, IPUSB2HD3, IPUSB2VGA2, PCI420USB, PCI625USB2I, PCIUSB7, PEXUSB4DP, PM1115UW, PM1115UWEU, RACKCOND1701, ST12MHDLANU, ST12MHDLANUR, ST4200MINI, ST4200USBM, ST4202USB, ST4202USBGB, ST7200USBM, ST7202USB, ST7202USBGB, SV231DD2DUA, SV231DDUSB, SV231DDVDUA, SV231DPDDUA, SV231DPDDUA2, SV231DPU, SV231DPUA, SV231DVIDDU, SV231DVIUA, SV231DVIUDDM, SV231HDMIUA, SV231QDVIUA, SV231TDVIUA, SV231USB, SV231USBDDM, SV431DD2DUA, SV431DDUSB, SV431DDVDUA, SV431DL2DU3A, SV431DPUA, SV431DPUA2, SV431DVIDDU, SV431DVIUDDM, SV431TDVIUA, SV431USB, SV431USBDDM, SV565UTPDUV, SV565UTPHDU, SV831DVIU, USB2001EXT2, USB2001EXT2NA, USB2002EXT2, USB2002EXT2NA, USB2004EXT2, USB2004EXT2NA, USB2HDCAPS, USB3EXT6INBK, USB421, USBEXTAA10BK, USBEXTAA3BK, USBEXTAA6BK, USBPLATE4
Customer reviews
Write a review for the StarTech.com 15 ft USB 2.0 A to B Cable - M/M here!
Excellent quality 15 foot cable
Reviewed by Anonymous Review Posted 07/06/2006
+ Excellent solid quality cable
Don't get confused by product description. It is really 15' (feet) long and beats any other cable (e.g. Belkin)
- Overall
- Ease of use
- Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
