Your basket is empty
StarTech.com 15 ft Orange Gigabit Snagless RJ45 UTP Cat6 Patch Cable
Quicklinx: 76N8WS00 Mfr#: N6PATCH15OR
Length: 4.6m
Colour: Orange
20 in stock
£5.40 ex VAT
£6.48 inc VAT
Standard delivery Delivered within 3-5 working days
Make Power-over-Ethernet-capable Gigabit network connections. The N6PATCH15OR Cat 6 Patch Cable (15 ft) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable orange PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Cat 6 Patch Cord delivers reliable performance.
StarTech.com 15 ft Orange Cat6 / Cat 6 Snagless Patch Cable 15ft - patch cable - 4.6 m - orange
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded, snagless
Length
4.6 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Orange
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Molded, snagless
Length
4.6 m
Orange
Connector
RJ-45 - male
RJ-45 - male
UL, RoHS, ETL - up to 650 MHz
Length: 4.6m
Colour: Orange
Price Range Ex VAT: 0 - 50
