StarTech.com 15 ft Monitor VGA Cable - HD15 MM
Quicklinx: 6BB8WS00 Mfr#: MXT101MM15
Select:
  • 4.5m
Attach a PC VGA port to a switchbox. This 15-foot VGA Video Monitor Cable features two HDDB15 (male) connectors, providing a high quality VGA connection.
The cable supports a maximum video resolution of up to 800x600. For applications that require higher resolutions, see 15ft Coax VGA Cable (MXT105MMHQ).
StarTech.com 15 ft Monitor VGA Cable - HD15 M/M - Supports resolutions up to 800x600 (MXT101MM15) - VGA cable - 4.6 m
VGA cable
Shielded
Length
4.6 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
RoHS
Grey
P/N: CDP2VGA, CDP2VGAFC, CDP2VGAUCPW, HDMIPLATE, MDP2VGAAMM2M, MDP2VGAAMM3M, SV231DVGAU2A, SV431DVGAU2A, USB32VGAEH3, VGAPLATE
VGA cable
Shielded
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
4.6 m
Grey
Connector
RoHS
