Connect a Mini DisplayPort-equipped PC or Mac to a VGA monitor/projector, with a 15ft long white cable. The MDP2VGAMM15W active Mini DisplayPort to VGA converter cable lets you connect your Mini DisplayPort-equipped desktop or laptop directly to a VGA monitor or projector at a longer distance than a standard-length cable would support, while saving the expense of additional adapters. The cable features a stylish white design, that is well-suited for connecting Mac computers.
Plus, because the converter cable supports video resolutions up to 1920x1200 you can convert a DisplayPort video source to VGA without sacrificing video quality.
- StarTech.com 15ft Mini DisplayPort to VGA Adapter Cable mDP to VGA - White - video converter - white
- Video converter
- Max Resolution
- 1920 x 1200
- 1 x DisplayPort output - Mini DisplayPort , 1 x VGA input - 15 pin HD D-Sub (HD-15)
- Enclosure Colour
- White
- 3-year warranty
- Video converter
- Max Resolution
- 1920 x 1200
- 1 x DisplayPort output - Mini DisplayPort - male , 1 x VGA input - 15 pin HD D-Sub (HD-15) - male
- Active cable (signal regeneration), Thunderbolt port compatible
- Cables Included
- 1 - 4.6 m
- FCC, RoHS, WEEE
- 234 g
- Enclosure Colour
- White
- Limited warranty - 3 years
- 0 °C
- 60 °C
- 40 - 85%
