StarTech.com 15 ft DVI-D Dual Link Monitor Extension Cable - M/F
Quicklinx: 6LBRWS00 Mfr#: DVIDDMF15
Type: DVI
Length: 4.6m
Hurry, only 1 left in stock!
£12.35 ex VAT
£14.82 inc VAT
Extend the connection distance between your DVI-D digital devices by 15ft. The DVIDDMF15 15ft DVI-D Dual Link Extension Cable allows you to extend the connection between your desktop workstation and DVI monitor, or your laptop and projector by up to 15-feet.
The dual link cable supports resolutions of up to 2560x1600 and transmission rates of up to 9.9 Gbits/sec, and is fully compliant with DVI DDWG standards.
This durable DVI male to female cable is designed to provide a high quality digital video experience.
StarTech.com DVI Extension Cable - 15 ft - Dual Link - Male to Female Cable - 2560x1600 - DVI-D Cable - Computer Monitor Cable - DVI Cord (DVIDDMF15) - DVI extension cable - 4.6 m
DVI extension cable - dual link
Length
4.6 m
Connector
DVI-D - male
Connector (Second End)
DVI-D - female
P/N: CDP2DVIMM2MB, DP2DVI2MM3, DP2DVI2MM6, DP2DVIMM10, DP2DVIMM6, DP2DVIMM6BS, DP2DVIMM6X10, DVIDDMF10, DVIDDMF6, DVIDDMM10, DVIDDMM6, DVIDDMMBA6, DVIDDMMTA6, DVIDSMM10, DVIMM6, HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6
DVI extension cable
TMDS Links
Dual link
Plated Connector
Nickel
Length
4.6 m
Connector
24+1 pin digital DVI - male
24+1 pin digital DVI - female
Type: DVI
Length: 4.6m
Stock Status: In stock
