StarTech.com 15 ft DVI-D Dual Link Cable - M/M
Quicklinx: 3ZL8WS00 Mfr#: DVIDDMM15
Type: DVI
Length: 4.6m
42 in stock
£13.05 ex VAT
£15.66 inc VAT
Make a high-speed DVI-D connection with StarTech.com's DVI-D dual-link cables. These quality cables provide a stronger, faster signal to keep the resolution on your panel display, digital projector, or HDTV crystal clear. These cables allow high-speed data transmission up to 9.9 Gbits/sec and are backed by lifetime warranty.
StarTech.com Dual Link DVI Cable - 15 ft - Male to Male - 2560x1600 - DVI-D Cable - Computer Monitor Cable - DVI Cord - Video Cable (DVIDDMM15) - DVI cable - 4.6 m
DVI cable - dual link
Length
4.6 m
Connector
DVI-D - male
Connector (Second End)
DVI-D - male
P/N: BNDDKTCHVPRS, CDP2DVIDP, CDP2DVIUCP, CDP2DVIUCPW, CDP2HD, CDP2HDUCP, CDPVDHDMDP2G, CDPVDHDMDPRG, CDPVDHDMDPSG, CDPVDHMDPDP, CDPVGDVHDB, CDPVGDVHDMDP, DK30BACDD, DKT30CHCPD, DKT30CHD, DKT30CHPDW, DKT30CHV, DKT30CHVW, DP2VGDVHD, DVI92030202L, HD2DPVGADVI, SV431DL2DU3A, SV431DVIUDDM, USB3SDOCKDD
DVI cable
TMDS Links
Dual link
Plated Connector
Nickel
Length
4.6 m
Connector
24+1 pin digital DVI - male
P/N: BNDDKTCHVPRS, CDP2DVIDP, CDP2DVIUCP, CDP2DVIUCPW, CDP2HD, CDP2HDUCP, CDPVDHDMDP2G, CDPVDHDMDPRG, CDPVDHDMDPSG, CDPVDHMDPDP, CDPVGDVHDB, CDPVGDVHDMDP, DK30BACDD, DKT30CHCPD, DKT30CHD, DKT30CHPDW, DKT30CHV, DKT30CHVW, DP2DVI, DP2DVI2, DP2DVID2, DP2DVIS, DP2VGDVHD, DVI92030202L, DVIEXTAA6IN, DVISPL1DD, HD2DPVGADVI, HDDVIMF8IN, HDMIDVIMF, MDP2DPDVHD, MDP2DVI, MDP2DVI3, MDP2DVIS, MDP2DVIW, SV221DVIDD, SV231DD2DUA, SV231DDUSB, SV231DDVDUA, SV231DVIDDU, SV231DVIUDDM, SV231QDVIUA, SV231TDVIUA, SV431DD2DUA, SV431DDUSB, SV431DDVDUA, SV431DL2DU3A, SV431DVIDDU, SV431DVIUDDM, SV431TDVIUA, SV831DVIU, USB2DVIE3, USB2DVIPRO2, USB32DVIEH, USB32DVIPRO, USB32HDDVII, USB3SDOCKDD, VSEDIDDVI
3ZL8 StarTech.com 6 ft DVI-D Dual Link Cable - M/M In Stock £6.69
3ZL8 StarTech.com 15 ft DVI-D Dual Link Cable - M/M In Stock £13.05
3ZL8 StarTech.com 10 ft DVI-D Dual Link Cable - M/M In Stock £10.71
Type: DVI
Length: 4.6m
Price Range Ex VAT: 0 - 50
