Product
StarTech.com 15 ft DVI-D Dual Link Cable - M/M
Quicklinx: 3ZL8WS00 Mfr#: DVIDDMM15
Type: DVI
Length: 4.6m
11 in stock
£13.17 ex VAT
£15.80 inc VAT
Make a high-speed DVI-D connection with StarTech.com's DVI-D dual-link cables. These quality cables provide a stronger, faster signal to keep the resolution on your panel display, digital projector, or HDTV crystal clear. These cables allow high-speed data transmission up to 9.9 Gbits/sec and are backed by lifetime warranty.
StarTech.com 15 ft DVI-D Dual Link Cable - M/M - DVI cable - 4.6 m
DVI cable - dual link
Length
4.6 m
Connector
DVI-D - male
Connector (Second End)
DVI-D - male
P/N: RKCONS2001GB, RACKCONS2001, SV431DVIDGB, SV431DVIDDU, SV431DDUSB, SV231DDUSB, VID2DVIDTVGB, VGA2DVIIGB, VGA2DVII, VID2DVIDTV, SV421DVIDD, SV221DVIDD, SV421DVI, SV221DVI
DVI cable
TMDS Links
Dual link
Plated Connector
Nickel
Length
4.6 m
Connector
24+1 pin digital DVI - male
StarTech.com 2 Port DVI PS/2 KVM Switch, 4 Port DVI Dual Monitor KVM Switch with PS/2, Composite and S-Video to DVI-D Video Converter with Scaler, High Res RackMount LCD Console for 19" Rack, VGA to DVI-I Video Converter with Scaler , StarTech.com StarView DVI KVM Switch SV421DVI
3ZL8 StarTech.com 6 ft DVI-D Dual Link Cable - M/M In Stock £6.71
3ZL8 StarTech.com 15 ft DVI-D Dual Link Cable - M/M In Stock £13.17
3ZL8 StarTech.com 10 ft DVI-D Dual Link Cable - M/M In Stock £10.60
Type: DVI
Length: 4.6m
Price Range Ex VAT: 0 - 50
