StarTech.com 15 ft Coax VGA Monitor Extension Cable - HD15 M/F
Quicklinx: 4L3BWS00 Mfr#: MXT105HQ
Type: SVGA
Length: 4.6m
13 in stock
£11.91 ex VAT
£14.29 inc VAT
Extend your VGA monitor connection without losing video signal quality. This 15ft High Resolution VGA Monitor Extension Cable is designed to provide the highest VGA video quality possible. Ideally suited for high resolution VGA applications (1024x768 and above), this high quality coaxial VGA cable eliminates picture "ghosting" and fuzzy images inherent to non-coaxial cables and provides superior EMI interference protection by using ferrite cores near the connector ends.
A reliable solution for a wide range of applications, including connecting StarView KVM Switches, this high resolution VGA (SVGA) extension cable features one hddb15 male connector and one hddb15 female connector, offering a convenient way to extend a VGA or SVGA connection by up to 15ft, while maintaining superb image quality.
StarTech.com 15 ft. (4.6 m) VGA Extension Cable - HD15 VGA Extension - Triple-Coaxial - Male/Female - VGA Monitor Cable (MXT105HQ) - VGA extension cable - 4.6 m
VGA extension cable
Triple shielded twisted pair coaxial
Molded, ferrite bead
Length
4.6 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - female
Grey
P/N: ST1212T, ST121REU, ST121RGB, ST122PRO, ST122PROEU, ST122PROGB, ST122UTPA, ST122UTPAEU, ST122UTPAGB, ST122UTPAL, ST122W, ST124PRO, ST124PROEU, ST124W, ST128PRO, STUTPRXL, USB3HDCAP
VGA extension cable
Shielding Material
Plated Connector
Nickel
Length
4.6 m
Grey
Connector
15 pin HD D-Sub (HD-15) - female
Type: SVGA
Length: 4.6m
Price Range Ex VAT: 0 - 50
