Product
StarTech.com 15 ft Coax VGA Monitor Extension Cable - HD15 M/F
Quicklinx: 4L3BWS00 Mfr#: MXT105HQ
Type: SVGA
Length: 4.6m
1 in stock
£11.78 ex VAT
£14.13 inc VAT
Standard delivery Delivered within 3-5 working days
Extend your VGA monitor connection without losing video signal quality. This 15ft High Resolution VGA Monitor Extension Cable is designed to provide the highest VGA video quality possible. Ideally suited for high resolution VGA applications (1024x768 and above), this high quality coaxial VGA cable eliminates picture "ghosting" and fuzzy images inherent to non-coaxial cables and provides superior EMI interference protection by using ferrite cores near the connector ends.
A reliable solution for a wide range of applications, including connecting StarView KVM Switches, this high resolution VGA (SVGA) extension cable features one hddb15 male connector and one hddb15 female connector, offering a convenient way to extend a VGA or SVGA connection by up to 15ft, while maintaining superb image quality.
StarTech.com 15 ft Coax VGA Monitor Extension Cable - HD15 M/F - VGA extension cable - 4.6 m
VGA extension cable
Triple shielded twisted pair coaxial
Molded, ferrite bead
Length
4.6 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - female
Grey
P/N: VGANTSCPROEU, ST124UTPEAGB, ST128UTPEAGB, ST122UTPAEU, USB2VGAPRO, ST121UTPMINI, ST122VGAU, USB2VGAE2, VGA2VID, USB2VGAE, ST128UTPEA, ST124UTPEA, VS410RVGAA, ST128W, ST124W, ST122W, USB2VGA2, ST122UTPAGB, VS815RVGAGB, VS415RVGAGB, VS415RVGA, USB2VGA, STUTPRXL, ST128UTPE, ST124UTPE, ST122UTPA
VGA extension cable
Shielding Material
Plated Connector
Nickel
Length
4.6 m
Grey
Connector
15 pin HD D-Sub (HD-15) - female
Startech Converge A/V 4 Port VGA Video Splitter - Wall Mountable, 8 Port VGA Video Splitter - Wall Mountable , StarTech.com 16 Port High Resolution VGA Video Splitter - 400 MHz, 2 Port High Resolution VGA Video Splitter with Audio - 400 MHz, 2 Port Matrix High Resolution VGA Video Splitter, 2 Port VGA Auto Switch, 2 Port Wall Mount VGA Video Splitter, 4 Port High Resolution VGA Video Splitter - 350 MHz, 4 Port High Resolution VGA Video Switch with Remote, 4 Port VGA Matrix Video Switch - 250 MHz, 4 Port VGA Video Audio Switch with RS232 control, 4 Port VGA Video Extender over Cat 5 (UTPE Series), 8 Port VGA and Audio over Cat 5 Video Extender, 8 Port VGA Video Extender over Cat 5 (UTPE Series), 8 Port VGA Video Selector Switch, High Resolution VGA to Composite or S-Video Converter PC to TV, Mini VGA Video and Audio Extender over Cat5, Professional USB to VGA External Dual or Multi Monitor Video Adapter, USB to VGA Multi Monitor External Video Adapter, USB VGA External Dual or Multi Monitor Video Adapter, USB VGA External Dual or Multi Monitor Video Adapter - High Resolution, USB VGA Mini External Dual or Multi Monitor Video Adapter, VGA PC to TV Video Converter with Remote Control, VGA to TV Video Converter with Remote Control, VGA Video Extender over Cat 5 with Audio , StarTech.com Converge A/V 4 Port VGA and Audio over Cat 5 Video Extender, 4 Port VGA over Cat5 UTP Extender, VGA over Cat5 UTP Receiver, VGA over Cat5 UTP Receiver/Extender , StarTech.com Professional VGA to NTSC/PAL TV Converter , StarTech.com UTP VGA/Multisync Video Extender , StarTech.com VideoView 8 Port VGA Video Splitter, Pro 2 Port High Resolution 350 MHz Video Splitter, Pro 8 Port High Resolution 300 MHz Video Splitter
Type: SVGA
Length: 4.6m
Price Range Ex VAT: 0 - 50
